Hello,
Figured out I need the.30 version of this combined switch for blinker, dimmer, flasher and parking light so this one can go. Good condition, stalk stays in position you move it to. Asking $195,- shipped.
Cees
Hello,
Cees
If you are looking for the 30 version. I have two of them brand new still in original Porsche boxes.
$395.00 plus shipping
GLWS
Erik
Good to know Erik, thanks. apparently there are two versions; a 301.30 and 303.30 (only flash on dimmed light), need to check which one I have now. The flasher function for the one that is in the car does not work anymore, that is for sure...
Regards,
Cees
Erik, pm sent and will purchase pending details of part number & condition.
—Juan Manuel Fangio[48]
”What would PORSCHE do”
911.613.301.00, which yr. is this from? My 72 has like number,,
Doesn’t the flash function only work from the dim position?
Hi Cliff,
I have the same one in my 72 and 73 cars, both with round lever compared to the 301.00 that has a rectangular lever and part number. Just found that number in the 1972 spare parts catalog, while the 72/73 spare parts catalog shows the 301.30 and 303.30 version. So probably mid 72 the change over occurred. Flash function on my 73 does not work when the low beam is on (light switch position two). In position one it flashes but only low beam. Could be an Italian thing so may be I have the 303.30 version. The 72 flashes with high beam with low beam on (position two on light switch) as you expect.
Regards,
Cees
