Results 1 to 8 of 8
Thread: Steering wheel extension hub on 911s 1967
    Nov 2018
    Malta
    Hi all,
    I am looking to extend out my existing steering wheel ( 911s 1967 ) for about 3 inches , this due to some difficulty in inserting the 1st gear ( my thigh hitting steering wheel )
    Can anyone guide me to a possible supplier ? SierraMadre have only 1 inch ones
    Thank you
    PORSCHE 911S '66
    Aug 2009
    SF Bay Area
    You need a smaller wheel, not an extension on your existing one.
    Jim
    Touche Sir James....Touche !
    Aug 2016
    NE Ohio
    Yes a smaller wheel and consider removing padding from the bottom of the seat to lower your torso. (BTW, that's a professional's job unless you are into upholstery.) . How tall are you? What seat do you have in the car?
    You might also be interested in: FS: '68-'88 911 Shift Lever Extension, $34.42
    Nov 2018
    Malta
    Hi Jackman ,
    I am 6'4 and large frame :-)
    Seat is the original from 67s but re upholstered centuries ago :-)
    When putting shifter into 1st gear ( the only problem ) it needs to go into my thigh
    PORSCHE 911S '66
    I'm about your size with long legs, I solved it in my 911 with a 1" extension and the 38cm wheel from a 914
    Quote Originally Posted by Bowzer View Post
    Hi Jackman ,
    Nov 2018
    Malta
    Quote Originally Posted by mcampuzano View Post
    Thank you mcampunzano
    PORSCHE 911S '66
