Results 1 to 7 of 7
Thread: When did ventilated discs become an option ?
    Can anyone tell me if ventilated discs were available on a 1967 911 Coupe ?
    When were they first available as an option ?
    Well they were certainly standard on the 67 S, don't know if they could be optioned for 911 normals however.
    Ed, Thanks for your response. Does anyone know if Coupes has ventilated discs in 1967 as standard ?
    Feb 2013
    Europe
    An S had them standard, not a normal coupe.
    I had a 67 normal, one of the last 500 built, it had ventilated discs. Everything else on the car was original . Since they changed over to vented for 68, I assumed they could have made the change on some late 67 normal cars but I ‘m only speculating. Is changing over to ventilated discs on the rear an easy switch or is there some difference in the hub?
    John Schiavone
    Connecticut
    Dec 2008
    Black Mountain, NC
    John, I think it is a simple bolt up, change calipers & rotors, Hope all is well!
    Best Regards
    Feb 2013
    Europe
    Quote Originally Posted by Jerry L View Post
    Best Regards
    And brake dust shields... At least they are specific on a 67s.
