Hi everyone! On my copy of SL33 there are 4 wires (2 red, 2 white) that just dead end up to the left of the fuse panels.one red wire goes to the weco connector at the terminal bar in the engine compartment.The other red wire comes off the emergency blinkers and goes to fuse 6 on panel #1.The other side of that fuse it The white wires do similar the same.Anyone know where these dead ended wiresT connect? car is '69T. Thank you T.C.
