Results 1 to 10 of 13
Thread: One less 901 out there
    I was moving some cars out of a storage barn today trying to get to a 914-6 that I'm going to restore. One of the cars I had to move was a 1966 S/R coupe parts-project car. It has a #s matching engine and trans. I put it in the barn about 25 years ago and had forgotten about it. Once the 914-6 was out and put on the lift I started to move the remaining cars back in the barn. I decided to give the 912 a look around, opened the trunk and deck lid. To my surprise the rear latch panel was flat, no indentations at all. For a fleeting second I thought that this could be a 901, then I noticed that the 912 had been clipped from the shock mount crossbar back. The original 901 engine mounts were hacked off and 912 mounts crudely welded in. The oil tank holes were left also. So this 66 912 was put back together by using a rear clip from a 901. Seems like a bit off a waste, but back when the work was done the 901 had probably been involved in a front end wreck and was just a parts car. Probably no way off ever knowing the identity of the 901.
    Oct 2008
    Burford, ON, Canada
    A nice collection there. If nothing else that panel could be used as a pattern.
    May 2011
    Chelsea, Québec
    That's a great suggestion... Restoration Design would probably be able to use it...
    Member #1616
    Dec 2003
    West Los Angeles
    Understatement of the decade: "...Seems like a bit of a waste..."
    techweenie.com
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    we could narrow the possible donor cars down by
    colour (if there is any of the original left on the fragments)
    position of the wiring tabs on the slam panel and wheel housing
    reinforcement plates on the oiltank holes
    probably other parts of the donor car where used like deck lid or doors etc.
    those parts should have 2 or 3 digits stamped in
    Moito here is a pic of the wiring tab and deck lid cable and tube from the back side of the slam panel. The doors are from the 912 but the deck lid might be a donor. Where would I look for any stamped digits? Thanks
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Here is a picture of the three digit ( last three of the serial #) location;in the yellow box. May vary slightly.....cliff
    (Photo from Early 911 S registry archives, photo by Bobs 67S, I believe.........) post# 11 guy
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    I think the early deck lids ('64) had a provision for a weather strip that ran along the back edge. Might be worth checking to see if that's present...if so, then probably worth finding the number (which might require sanding) and also could be useful to someone restoring a 64.
    I checked the deck lid for stamped numbers and came up empty. While I had the sander going I buzzed off the surface rust on the slam panel, treated it with a rust converter and primer. The panel has 3 or 4 areas of lead along its length (along with the edges where it is welded to the rear quarters). It seems care was taken to make this panel as flat and smooth as possible. If anyone is restoring a 901 and could use this panel let me know, its yours.
    May 2013
    AUSTRIA (tu felix)
    it appears as if the deck lid catch is the early type without the adjusting hole---is it? if so i`d be interseted in buying it
    the 2nd foto shows the rail for the weather strip on the lid
