Results 1 to 10 of 19
Thread: Restoring my 1971S Gemini Blue
    Dec 2013
    Connecticut/Florida
    So while the car is at the body shop being prepped for painting
    Attachment 499560
    Attachment 499561
    1971 911S Coupe - Gemini Blue
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    Wow. Love it.
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    Jun 2003
    Toronto
    Nice work on restoring the panel! I see that you also have a 2-stage rear window defroster relay, I can't seem to find a wiring diagram for this circuit and I'm in the process of reconnecting mine. Can you tell me where the red wire on the bottom left goes to, I'm assuming the 3-fuse panel but not sure.
    Rudy
    Your 71 should have the large panel cover, I see the wing nut to retain it. With the large cover no fuse cover was used.
    Quote Originally Posted by rvdv View Post
    Rudy
    If you mean the two pole connector at bottom far left, that plugs into the two pole connector from the window harness.
    Dec 2013
    Connecticut/Florida
    Rudy
    Yes, that fat red wire goes to top right of 3 fuse panel. There is a smaller red that goes to the connector. Easier to see on the refinished unit.
    Dec 2013
    Connecticut/Florida
    Ahhhhh...that makes sense. Thanks
    Ditto on the large panel cover, but should the large panel cover have a wing nut or the large round nut with the grove in the middle or was that only for 72/73?
    Jul 2011
    Chicago Area
    Was your car produced after January 1st '71?
    Mike Fitton # 2071
    2018 911S Carrera White
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by mfitton View Post
    No, 11/70 production
