Results 1 to 1 of 1
Thread: FS: Restored Improved 911 Pedal Set 1969-1975, $425 outright or $325 with a core.
    May 2006
    Riverside CA 92505
    Sold. Check for new post with the same type pedal set.
    This is a 911 pedal set for 1969-1975. It can be used for 1965-1968 911 and 912 if the master cylinder is changed to the later dual circuit type. Also fits 1970-1976 914. The 914 uses a different upper clutch pedal. I can also set it up with the longer push rod to use with the 1965-1968 SWB cars.
    The parts have all been stripped and the housing, shaft and cross tube are zinc plated.
    I have added a ball bearing in the clutch shaft to replace the bushing which is the first one to wear out in the pedal set.
    The housing and pedals are powder coated. New bronze bushings and new springs and stopper are installed.
    The price shipped in the U.S. is $425 outright. If you have a core the price is $325.
    International shipping by USPS Priority Mail at shipping cost. Typically about $75.
    You pay the core charge and when the core is returned the charge is refunded.
    I have one built at this time and have parts to build several more it needed.
