Results 1 to 10 of 12
Thread: Battery fitment...two down to one
    This horse has been beat to death...I know. Yes lots of threads on this...and I have read them all...probably. I have narrowed my focus to a Deka 75 and an Oddyssey 925.
    My concern is fitment in my 72 drivers' side battery box. The manufactures dimensions are way bigger than my battery box. But they list dimensions as "packaging" dimensions. Has anyone installed a 925 L in a 72? I have seen a lot of pics of them mounted in Porsches...but the later cars have more room than my little 72 battery box. If so would you mind forwarding me a picture? I like the AGM as I can mount it anyway I want...and I am likely going to order one with the + on the left side.
    TIA
    Speedo
    registry# 1283
    Aug 2009
    SF Bay Area
    I had to build shims behind the battery as it was too small. I chopped off the RH battery box for my oil cooler and ducting. Cranks like crazy, though. I stole this battery from my son's Comet Caleinte.
    Jim
    PS: Highly recommended!
    Dec 2008
    Black Mountain, NC
    +1 I put the same in my 71, also some wood to space the battery out into the trunk area and give the posts / clamps some comfort room away from the top of the batt box & possible shorting. Very happy with that battery!
    Aug 2011
    Eugene, OR
    I put a pair of Miata AGM batteries in my '72. Those also require some shimming to mount adequately. While I went ahead and did both of them, I'm sure that a single Miata battery would be more than sufficient.
    - Arne
    Oct 2010
    Southern Ca.
    I put an Odyssey PC 925 in my '73 . I used an approximately 2" by 6" plastic block from McMaster Carr under the strap to hold the battery tightly , no shimming and no terminals to worry about .
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Cool
    I gave up on lead acid batterys, I also went with the Odyssey PC925 and a very nice bracket from Patrick Motorsport
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Jun 2012
    London, Ontario, Canada
    I went with two Odyssey PC925s, but 1 would suffice I am sure. I used a cut piece of 2x4 on each side and one on the top ensure that the battery stays put and keeps the terminals clear of the top of the battery box. The 2x4 on the top means that standard strap works fine. No need to buy the $78 Patric Motorsport piece of metal. I do have a plan to make and paint some wood cases to put the Odysseys in that would look a bit more finished with decals or cut the white part of the Interstate 911 lead acid batteries I took out and make a more elegant case for the Odysseys. But life is interfering at the moment.
    Early 911S Registry # 2395
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Probably a major break with purists but the Rennline relocate kit for the 925 in the smugglers box makes for a very tidy package (no affiliation)
    Isn’t the 925 cranking amperage to low? I was about to purchase one this weekend, now I’m back in the forum for reassurance.
    1968 911L, but swapped to a 2.7L fuel injected from a 76S. Is this enough battery?
    Aug 2011
    Eugene, OR
    Quote Originally Posted by Rex1968s View Post
    Should be fine. My '84 Carrera 3.2 had a PC925 in it when I bought the car. Prior owner installed it 2 years prior to the sale. I drove the car for another 7 years, battery worked fine the entire time, was still cranking hard when I sold the car. I can't imagine that your 2.7 would be much different.
    - Arne
