Page 22 of 44 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 435
Thread: 300090
  1. #211
    Still doesn't explain the purpose of the hole?
    I went up the attic where there is a NOS right side inner fender.
    No hole, no welds.
    Richard
  2. #212
    Senior Member 300090's Avatar
    Sep 2019
    FRANCE
    Hole and welds on 1964 front shock tower
    Quote Originally Posted by preS View Post
    No hole, no welds.
    Richard
    Hello Richard,
    Here is an example that belongs to a friend.
    I don't know exactly what year it is.
    • Non-adjustable
    • He doesn't have the reinforcement.
    • We can see the hole and the weld.
    I'm not sure I understand the angle of view of your photos.
    On your photos of the inner fender I do not see the "washer": red arrow on my first photo.
    Your fender seems to have the reinforcement: how is this possible on an NOS part? Would the reinforcement have been welded at the factory?
    Here is the photo of the 300133 (1964) posted by Bob on this thread:
    https://www.early911sregistry.org/fo...=1#post1067766
    @Bob: do you think the hole and the weld could be hidden behind the reinforcement?
    Philippe
  3. #213
    Shock Tower Weld
    Philippe,
    It appears to me that the rosette weld is about 1/3 of the leading side down from the horizontal flat . 300 133 appears to not have the weld - 331 maybe.
    As a note 300149 (a December 1964 car) did not have any dealer welded on cap supports or rosette weld. That car had 407,000 miles when it moved along to a new owner. No shimmy's or shakes in the steering and it had been WELL used. Aluminum, original, light weight steering wheel had a leather wrap for 30 years. Stiffer torsion bars, and uprated anti-roll bars. Street and track used.
    Bob
    Early S Reg #370
  4. #214
    Sep 2019
    FRANCE
    Shock Tower Weld
    Quote Originally Posted by Bobs 67S View Post
    Philippe,
    Thank you Bob and Richard,
    We plan to fill the hole and therefore not make the rosette weld.
    Philippe
  5. #215
    Sep 2019
    FRANCE
    Tow hook for 1964
    Hello,
    The PET shows only one version of the tow hook: 901 501 530 20 / 90150153020
    Do you know if previous versions have existed: .00 or .10?
    Do you think 901 501 530 20 is correct for my car?
    Thank you,
    Philippe
  6. #216
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Here is a lead on tow hook for the earliest of cars: https://www.early911sregistry.org/fo...front+row+hook
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
  7. #217
    Sep 2019
    FRANCE
    Tow hook for 1964
    Quote Originally Posted by Cliff View Post
    Thank you Cliff.
    Philippe
  8. #218
    Junior Member
    Jul 2018
    Sparks, Nevada
    The present number for the tow hook is 901-501-530-20-GRV and available from most sources.
  9. #219
    1964 vs later front tow hooks
    The 4 main difference areas between the 1964 and later tow hooks are:
    the side view - note the later has right angle bends while the early has a definite deep "Z" bend
    The Rod attachment indents on the later are more parallel - early has more "V".
    Front bend, later is rounder verses the early more "V" shape.
    Note the other difference is the tipped out at he sides that mate to the stamped half round shapes on the lower gas tank support cross panel.
    Hope this helps:
    Using others photos (Thanks Allen).
    Bob
    Early S Reg #370
  10. #220
    Sep 2019
    FRANCE
    Tow hook for 1964
    Hope this helps:
    Thank you Bob!
    I am sure that these details will allow the 300090 to receive a proper tow hook.
    Philippe
