Page 7 of 44 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 435
Thread: 300090
  1. #61
    Senior Member 300090's Avatar
    Sep 2019
    FRANCE
    Dashboard disassembly
    Hi all,
    Some pictures of the dashboard during the disassembly.
    The dashboard top is in pretty good condition:
    Note the original Bali Blue paint on the top of the dashboard:
    Next post: dashboard stripping and VIN SCAN.
    Philippe
  2. #62
    Feb 2007
    Cheshire, UK
    Dash pad query
    Phillipe
    Really enjoying this thread and well done for documenting it all.
    Quick question for the 1965 experts - is the '65 dash pad the same as a '66/67 (as below) with the addition of the four 'buttons'?
    Tim
    Early 911S Registry #1167
  3. #63
    Sep 2019
    FRANCE
    Dashboard stripping and VIN SCAN
    Hi all,
    More pictures of the dashboard: stripping and VIN SCAN.
    The car being stripped:
    VIN SCAN by Kobus Cantraine:
    Do not forget the backside:
    Philippe
  4. #64
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    no yellow Faber Castell crayon on the Dashboard.... any unusual finds in hidden corners? coins, papers?
    you work fast in disassembling and blasting off the color.
    br
    haul
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  5. #65
    Sep 2019
    FRANCE
    Quote Originally Posted by haul View Post
    br
    haul
    Hi haul,
    There was no “yellow” inscription on top of the dashboard.
    Does anyone know if in 1964 the factory systematically wrote the chassis number on the paint of the dashboard?
    Would you have any examples?
    Are we working (too) fast? I don't think so.
    We take the necessary time:
    • We disassembled the car in November 2018.
    • We did strip the car three months later in February 2019.
    We made over 1000 pictures during disassembly.
    If you want to see more pictures tell us which ones and we will share them with pleasure.
    Philippe
  6. #66
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 300090 View Post
    Hi haul,
    Philippe
    no crayon on the dash on `64...the only crayon on body parts i found so far was a signature like scribbeling on both doors... crayon also on the inside of the door panesl(date code) and on the cardboard in the trunk
  7. #67
    It's too bad you blasted off the original Aga blue paint. It looked like it remained near perfect under the dash. Always nice to keep those original touches original, otherwise it will be a completely new car after the restoration with no original bits left.
  8. #68
    Sep 2019
    FRANCE
    Quote Originally Posted by erick72pors View Post
    The original color is Bali Blue.
    The car was fully stripped to remove any rust.
    When the body work will be finished the car will be stripped again.
    Followed by the application of a prime coat using a cathodic dip coating bath.
    How could we keep some of the original paint after this necessary treatment?
    Philippe
  9. #69
    May 2013
    AUSTRIA (tu felix)
    Philippe
    Philippe ,where do you go for the dip?
    BTW the ash tray cage is still in place...remove before dip.
    what do you do with the silencer in the door sill? fill with steel wool (thats what i did) or weld /solder in after the dip
  10. #70
    Sep 2019
    FRANCE
    Thank you for your advice moito.
    We plan to do the dip by a partner of the company that does the stripping.
    These 2 companies are in France.
    They are distant from each other by only 30 km.
    This will allow the dip less than 1 hour after the final stripping.
    Philippe
