Thread: oil thermostat internals
    Jan 2011
    Sunny Southern France
    Hello!
    Need help please! Would any of you know if it's possible to find spares for the intrenals of this oil thermosat?
    It's composed of 1 spring, 1 piston with the thermal bit in it.
    There are some parts listed for later cars like 930, but no idea if they can fit or have the same characteristics (travel, spring rate...)
    If somebody knows another car/make ... please share.
    Thanks!
    Olivier.
    Jan 2011
    Hi,
    if it helps, parts I'm looking for are 6, 7 and 8 below. 8 being the spring
    Any input greatly appreciated.
    Hi Olivier,
    Have you seen this bit of kit? It looks the part, but not sure if the dimensions are the same. Might be worth contacting one of the sellers and see if them will send you some details before buying. If the diameter is the same it may even be something you can machine to play.
    https://www.ebay.com/itm/Porsche-911...oAAOSwMg5cNceF
    I did a search on eBay for, "Behr thermostat Porsche 911"
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Jan 2011
    Hi Brad!
    At least, someone replied me =)
    I've seen different "kits". I'll try to get in touch with some vendors, in the worst case, I'll buy one and see what I can do with it.
    The issues are that temp aperture, travel and so on can be a problem, but, let's check if its possible to get some answers
    Thanks a lot!
