Thread: Help removing front bumper on 71T
    Nov 2017
    Los Angeles
    Hi All:
    The time has come to refresh the front bumper on my 71T. From my research, it looks like there are 6 bolts holding the bumper on: 2 on the side; 2 that can be accessed through the pan; and 2 on the vertical walls near the battery (or in my case, batteries) in the frunk. Is this correct?
    Does anyone have a picture (or pictures) more specifically identifying where these bolts can be found? I’d like to get an idea of their locations, even if rough, before I tackle the task.
    Thanks in advance!
    Dec 2015
    NE Michigan
    Hope these help.
    I think middle bolts are torx like and can be accessed thru holes on vertical wall of front panel. My experience on 1969.
    Dec 2010
    Southold, NY
    Apparently "frunk" is a linguistic version of Whack A Mole. Just when you believe it has been eliminated someone new thinks it clever and it raises its head once again.
    Nov 2017
    Los Angeles
    Quote Originally Posted by Phil Planck View Post
    Hope these help.
    Quote Originally Posted by ejboyd5 View Post
    Thanks for the info, Phil! One final question: Can these bolts be accessed while the car is on the ground or do I need to get the car in the air?
    As for using the term "frunk," I'll have a friend put me in time out . . .
    Name:  endurance-racing-champion-oliver-webb-gets-locked-in-2018-porsche-911-gt3-frunk_2.jpg
    Dec 2015
    NE Michigan
    Can be accessed on the ground.
