Thread: Turn Signal Assembly
    Hello,
    I have a 1973.5 911t
    I am installing a new turn signal assembly due to non working turn signals
    I have replaced
    Fuses
    Relay
    And now the assembly
    Could someone confirm where the below pictured wires from the assembly are to be connected to?
    The stalk has 2 pigtails
    One has
    1-Red/white
    1-Red/grey
    1- White/black
    1- Black/grey
    1- solid grey
    The other
    1- solid black
    1- green/black/ white
    Thanks for any help!
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    Not to be a wise guy, but did you record the wire placement when you removed the original one. If not I think you will have to reference the wireing diagram. Rob
    Quote Originally Posted by 30westrob View Post
    Hey rob,
    I did note some and have installed the assembly but my turn signals are still not working so I thought I’d make a thread to confirm where the wires go to make sure that’s not the issue.
    The stalk works fine for my headlights both low and high beam.
    My emergency hazard lights also work fine and I can hear the relay (new) click when the hazards are on.
    Here are some shots of 72-73 wire diagram .
    Not sure if this will help but also note the wires at the fuse block....9&10
Size:  156.6 KBName:  77A49B87-B647-45B7-86C0-979ACD93BBFE.jpg
Size:  155.9 KBName:  7717ED69-5B14-4B6E-A0F7-797DB325BEBE.jpg
Size:  120.8 KBName:  17A984C0-04BB-4D88-85E3-B15D9F619808.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    So following the diagram looks like
    -red/white 30 goes to 30 on light switch
    -solid grey P goes to steering ignition starter switch
    - grey/black 58L to 58L on light switch
    - grey/red 58R to 58R on light switch
    - white /black 56 to 56 on light switch ( also shows yellow off same terminal)
    Think I have these correct from the diagram
    Let us know how progress goes
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
