Results 1 to 10 of 18
Thread: 1967 911 - Dash paint
    Apr 2013
    Northern California
    I'm restoring my 1967 911 coupe. The dash board trim is bushed aluminum and the dash color is black. I'm trying to find out if the finish was Gloss, Satin or Flat. Any ideas?
    Don
    Satin...all day.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    SEM 39143 - Trim Black
    Cheers
    JB
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
    OK...I use the SEM plastic products on plastic substrate, but prefer VHT Satin Black Epoxy (purple label) for metal. Tough, solvent resistant.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    SEM Trim Black will do the trick, but I prefer the SEM Hot Rod Black kit. Same sheen, but it is catalyzed for much greater durability. Must be sprayed on of course.
    Apr 2011
    N.Calif., south of SF
    My experience with black satin varies quite a bit manufacturer to manufacturer. I ended up sampling several before landing on the one that appears correct.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Apr 2013
    Northern California
    Thanks for all the suggestions. Really appreciate it.
    Don
    Feb 2007
    San Diego
    Quote Originally Posted by Jim Morris View Post
    This is the only answer you should pay attention to. The spray can stuff will wipe off if some kind of solvent is used while cleaning the car in the future.
    Glasurit rallye black
    Joris,
    Do you have any pictures of the Glasurit Rallye Black on the car? I am interested in getting some and trying it out.
    On my 1967 Prototype R build I used Vintage Flatz - their Hot Rod Satin Black for the steering column and wheel. Happy with the results.
    https://vintageflatz.com/collections...ar-or-slow-kit
    Brad Davis
    RGruppe #691
    Early 911S #1547
