Results 1 to 7 of 7
Thread: Sorting rust in petrol tank
    I have a 1967 original petrol tank that I would like to keep on the car.
    My restorer is very reluctant to put it back on the car.
    Has anyone resolved the issue of rust ?
    Do more recent tanks have any kind of protective layer ?
    The rust does not look terrible.
    Mar 2006
    Louisville KY
    Do what you can to save the original tank. Most city’s have a place that can clean the tank for you.
    Tony Proasi
    52 split window coupe
    Oct 2014
    near Champaign, Illinois
    Check out Caswell.
    They have a system/sealant that will work.
    Jay
    1946 Willys Army Jeep
    1956 356A Cab
    1957 356A Speedster
    1959 Austin-Healey Sprite
    1962 356B Notchback
    1969 911T 'Speedster'
    1971 911S
    1974 Ford Ranchero
    1986 911 Carrera Cab
    1993 Audi V8Q
    2001 Mazda Miata 'Daughters Car'
    2008 Audi S6
    2018 Panamera 4S 'Wife's Car'
    It sound crazy, but white vinegar works really well to get the rust out. When you buy it by the gallon it is around $3/per here in California.
    The only trouble is you may have some pinhole leaks once you remove all the rust. I had this problem and had to use RED-KOTE sealer in the tank. I am pleased with the RED-KOTE so far.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Member AKAMick's Avatar
    Sep 2018
    77°50′47″S 166°40′06″E
    Have used the regular Blue liquid toilet bowl cleaner on a fuel tanks from motorcycles, acidic stuff removes rust quite well, must be neutralized with fresh water well, then treat with light oil to prevent flash bloom rust.
    Current fleet, mostly rubbish automobiles and other assorted junk.
    I'll offer different advice...you made mention of a 'restorer', so I suspect the car is not entirely still original so I'd recommend a new tank. Personally, I would never considering doing anything other than that...the risk of it not being done perfectly and a follow on concern of the internal coating finding it's way into the fuel system is a deal breaker for me. I personally replace everything in the fuel system - front to back.
    Sep 2012
    Colorado
    My body shop discarded the original tank without asking me. I was rather displeased, as I would have restored it myself, which has become fairly standard practice. A '67 would justify the effort.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
