Results 1 to 10 of 20
Thread: Source for correct factory gray muffler paint in EU
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    I´m looking for a source for High-Temp Exhaust Paint in the correct Factory Gray located in Europe or any who will ship to Europe.
    Wurth no longer sells gray muffler paint. And the gray paint from VHT is not a close match to the original factory gray.
    Stoddard and Sierra Madre sells gray paint, probably close to the original Factory gray, but refuses to ship to Europe. It does not matter to them that it can be sent by boat and not by air. Many thanks for that
    Any help is appriciated
    Best Nick
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    result this is the stoddard link. Do you your know if it is a water base or other?
    Is this what you are looking to ship to Europe...cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    I was really disappointed with the Stoddard exhaust paint. Tried it a couple of times and while the color was a good match to original, the paint turned purple/pink at hot spots. Really unsightly and much worse than looking at the VHT gray which is too light but doesn’t turn pink. Unless they’ve changed the formula recently and it can be verified it no longer changes color, avoid the Stoddard stuff. I have a couple of cans left which I refuse to use.
    Jul 2012
    Stockholm
    Cliff,
    Thats the paint I’m looking for. Stoddard also sells that paint in aerosol cans. https://www.stoddard.com/nla09500600.html
    Looking for either Aerosol Cans or Quarts. Its a Silicone Copolymer.
    Best Nick
    Jul 2012
    Stockholm
    356rider,
    I’ve been told that they have solved that problem.
    Also see the info from the manufacturer regarding that problem:
    https://highland-international.com/s...exhaust-paint/
    Best Nick
    Quote Originally Posted by 356rider View Post
    That would be great if the problem is solved, however it was an issue for several years and it would be good to hear from someone with first hand experience with the new formulation.
    Jul 2012
    Stockholm
    I'm willing to give it a try But my problem is to get that opportunity.
    But there must be someone on the forum who have dared to test the new paint?
    Best Nick
    Jul 2012
    Stockholm
    Late report. I´ve tried the exhaust paint from Highland and I´m very pleased with it
    Best Nick
    I've tried the current Stoddard muffler paint.I was pleased with color and performance.
    I’ve always used the VHT SP104, super durable, light gray.
