Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Muffler Strap Bolts?
  1. #11
    May 2006
    CT
    I have a few used, original muffler straps in decent condition. PM me if you need a pair.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  2. #12
    Feb 2007
    San Diego
    all the straps are the same. The bolt is unique for SWB as it has that small hex head and big shaft. LWB is the 13mm head but allen function the best. I have had to use a separate set of bolts to put my cars together then once all is in place you swap with the correct fresh plated part otherwise you scratch the bolt to death getting it together the first time and all your plating work is ruined.
  3. #13
    No, muffler hanger mounted to rear engine console with straps and no cushion on all long hood cars.
