Thread: Brake caliper size??
    Hi
    Having a moment and can't remember which car has a frt brake caliper piston size of 48mm
    Can anybody help. I think that a T are those size. Actually rebuilding some early Jag xj6 calipers for a buddy of mine and everyone is out of stock on caliper kits ( don't want to use Centric ones )
    Thanks, Rick
    Oct 2008
    Burford, ON, Canada
    Basically all 911 & 912 from 1969 on into the 80's, including the aluminum S calipers and the later A calipers used on the SC.
    The 1965 to 1968 cars also had 48mm pistons in the front calipers.
    There are 3 basic Piston designs -
    Early calipers used a 'damper' piston which had an anti-knock back bush and a steel pin in the caliper body.
    Aluminium S calipers used a similar damper piston which is longer than the piston used in the cast iron calipers
    SC Calipers used a simplified piston that dispensed with the knock-back devices.
    The early XJ6 has an unusual Girling Caliper that had 3 x pistons - There was a single 2.25" diameter piston in the outer caliper half and 2 x 1.6" diameter pistons in the inner caliper half.
    Thanks guys I only need the seals and rubber boots so a couple of kits will fix me right up for the Jag They are only 4 pistons per caliper with the 48 mm pistons
    The calipers must be from a Series2 or Series 3 car
