Thread: MFI microswitch replacement
    So the MFI microswitch is a pretty spendy piece of kit if you ask me.
    For $175, you get a normally closed momentary switch.
    Is there any reason why something like this ($10) wouldn't work if you came up with a little bracket to hold the switch in the correct position?
    Obviously whatever generic switch you choose needs to be robust to handle the many, many times it's going to be toggled.
    Like the "factory" micro switch is all that good?
    I've got lots of them in the micro switch graveyard.
    Thoughts?
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Yes you could make those small push Botton switches work, I don't think they would last too long. I found a source for the OEM ( 95% correct ) micro switch from "Newark Electronics". Size is the same but the micro switch boot is orange instead of black. Also it has a 3rd connector blade to make it NO or NC. I will Check on the price again but the last time I ordered them they were about $20 each.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Sep 2006
    Bend, Oregon
    They are still available at Newark Eletronics, part # BZ-2RDS5551-A2 for $29.00.
Size:  125.3 KB Name:  IMG_2645.jpg
    Mark Jung
    MFI Werks
    R Gruppe #686
    Mark, that is a much better solution as well as price. Nice find there. Will get one for a spare.
    -Doug
    Nice Mark …. Thanks !!!!
    Awesome Mark.
    And googling you can see the list of all the sellers and what they have in stock. Europe too.
    https://sensing.honeywell.com/distri...BZ-2RDS5551-A2
