Results 1 to 8 of 8
Thread: 65/66 experts - help needed
    Sirs,
    A friend is restoring a very early 66 solex car (65 build date w' non-adjustable front struts). Extensive metalwork is happening. During his research, he found a photo with a couple extra brackets that he cannot identify. Can anyone tell us what the brackets are and if they should be on his car?
    Thanks!
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Windshield washer pump bracket and the bracket for the washer tank reservoir. They should be on a late 65 or 66 car
    Thank you! Anyone have better pics?
    10 sec 67 VW
    Apr 2008
    Virginia's Blue Ridge
    Dave, my 302316 also a 65-built 66 still was fitted with the bag type washer reservoir thus no bracket in front for the SWF bottle type reservoir.
    Junior Member
    Oct 2010
    WA State
    From an early '66 build car. Name:  IMG_4788.jpg
Size:  121.7 KBName:  IMG_4785.jpg
    Sep 2006
    La Quinta
    Quote Originally Posted by Soterik View Post
    Dave,
    Maybe a better question is do you have a 1"+ size hole "behind" the shock tower on the passenger side? Because if you do, then you wouldn't need the bracket for the washer bottle. May not need the bracket for the pump either as isn't the pump up need the hood shock tower on the earlier cars (I have no clue, my world pretty much starts and ends in 1967).
    e
    Yep the pump sits right behind the hood shock.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    nice stuff fellas!
    www.tcspeed.com
    Thank you all. It looks like this car predates the hard washer bottle. Thanks for the input
    10 sec 67 VW
