Thread: 73 turn signal switch restoration
    Mar 2016
    U.K.
    Hi,
    My turn signal switch works but it doesn’t have a definitive click and auto release when the steering comes back to neutral. I tend to have to cancel the signal myself. Has anyone had a similar issue and had any success in fixing this? I don’t really want to change to the spare round stalk version I have.
    Gitesh
    May 2006
    CT
    Check you cancel ring. It may not be correctly positioned on the steering wheel hub.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Recently had this same issue with a '72 turn signal switch. I Very Gently cleaned and lubricated the three springs and other moving parts in the switch mechanism and that solved the problem.
    Mar 2016
    U.K.
    Thank you. I appreciate your help.
