Thread: Passenger side turn signal problem
    Jul 2018
    Maastricht
    Hi, i have a strange problem on my 1970E targa.
    Blinkers workers fine but the tachometer was broken. My garage built in a spare tacho, and that works fine now. But now the passenger side blinkers don’t work anymore. Both indicators blink and relay ticks. Passenger side works but indicators don’t work.
    Please advice.
    All the best,
    Joepjohan
    Oddly, this exact issue just happened to me. Identical circumstances. Did you ever find the culprit?
    -e
    Okay, Fixed! With the exact issues you had, Joe, it turned out I had to replace the flasher relay (behind the fuel level gauge) and a fuse. Weird that the fuse looked okay, but running a test light on it, it was faulty. Everything works as it should now: the directional indicator only shows one arrow and it blinks as the blinkers do. I hope that helps you out.
    -e
