Thread: Passenger side SWB turn signal lens or assembly with no cracks or fading
    Looking for a good restorable SWB US passenger side front turn signal lens. Will probably have to consider a complete assembly but only need the lens. Looking for one without cracks or deep pits/sand blasting
    Tia
    JK
    Tia
    JK
    So, you have found a non destructive method to remove the lens from the housing and be able to reuse it? Youdaman!
    Ciao
    PS: I'v e got a few nice housings but no perfect lenses.
    I have Jim. Will be in your neck of the woods next week. Will send you a PM
    Cool! You can have this SWB turn signal assy. The lens is 91% perfect. It would have been 100% perfect if not for the fire. Oh yea, it's a left instead of a right. Doh!!!!!!!!!!!
    Please share. I'm about to do this now...
    23. Defendants denied Plaintiff’s books-and-records request and inaccurately asserted that the Registry does not have any members. When Plaintiff and other members authored hundreds of online forum posts challenging Defendants’ actions and demanding that the Registry release records, Defendants deleted and censored those posts in an attempt to retain control over the Registry’s members and suppress members’ rights.
    Don't you just love great writing? I know I do!
    Bump, still looking for a good original lens or unit
    I have removed a bunch of swb signal lenses. I use a die grinder with a pointy rotary file to get the melted tabs small enough to pass throuh the housing, drill the inner end of the rivets and just work the lens loose from the housing adhesive without stressing it too much.
    Paul Chappel ( Rooute66kix ) has the passenger side in FOR SALE section.
