Thread: Heater/Fresh Air Control lights?
    May 2006
    CT
    The '72/73 Heater/Fresh air controller in the cockpit has (4) bulb holders as shown. One bulb comes off the harness on the controller itself. One bulb is used only when there is a gas heater. I think the other two are illumination lights that light up when the headlights are on. It looks like this is a separate harness that must daisy chain off the instrument lights. Can anyone confirm this? Or is it a part of the main under-dash harness?
    Is there a source for the buld holders if I decide to make up a spearate harness?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2011
    Eugene, OR
    Tom, my very early '72 (8/71) only has 2 bulb holders, the red (for Webasto) and the blue (for the vent fan). The other 2 do not exist on the earlier control console. I think you can see the difference from the outside by the shape of the white triangles. Tall narrow up/down arrows are not backlit (but appear to be glo-in-the-dark instead). The wide triangles can be backlit.
    As far as where to get the bulb sockets, I'm not sure.
    - Arne
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    The illumination lights for the fresh air control, gauges, ashtray, etc. all come from a separate daisy chain harness. I gets power from the headlight switch and is dark wire, blue or black with a white stripe.
    I would suggest you contact, timmy2 on Pelican as Dennis makes this harness with it’s incorporated bulb sockets.
    Rob
