Thread: Fire Supression for 77 mag case
    Sep 2012
    Philadelphia, PA
    Has anyone here ever put in some kind of fire suppression system for a mag case? I know you need a class D extinguisher (sodium chloride), which generally comes in 30 lb bottles.
    OR
    should I just keep my fingers crossed? I do have fuel lines checked frequently.
    Mostly curiousity...
    Serge
    Early S Registry #2457
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    I have seen this over in Samba...looks simple and fool proof
    \ https://www.blazecutusa.com/
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Sep 2012
    Philadelphia, PA
    I remember reading about this; however, it’s only for Class A B C. Magnesium is class D. Thank you anyway
    Serge
    Dec 2010
    Southold, NY
    Your magnesium case will not spontaneously ignite. It first must be heated by another source such as a fuel or contents fire which can be extinguished using a Class A B C agent. If a magnesium housing is actually burning you will have already lost a substantial part of the automobile to a more conventional fire so you might just as well step back and not get hurt. Class D fire extinguishers are heavy, expensive, and rarely around when you need one. In my 40 years in the fire service I have used a Class D only once.
    Sep 2012
    Philadelphia, PA
    Thanks EJ, for the info
    Serge
