Thread: Oil cooler damage?
    Oil cooler damage?
    Slowly moving along with my '69E, I will bring the fuel tank, oil tank, and oil cooler for cleaning.
    While removing the oil cooler from the engine (AKA the mice's toilet), I realised there is a non-original bend in it, see pics.
    Assuming it checks out without leak, and gets cleaned, can I re-use it as is, or should I try and straighten it?
    I wouldn’t try to straighten it,might further weaken the aluminum. Have it super cleaned, pressure tested and use it. If you had a open checkbook, and you were building a show car, then you could replace it. It got banged at some point.
    Hi Rick,
    OK no straightening, only cleaning/testing.
    Yeah, money tree died last winter, rats.
    Money trees often get stripped during major restoration........ask me how I know.
    Aug 2011
    Eugene, OR
    LOL! I don't have a money tree, never have. Just a rather small bush. And the body and paint work now wrapping up has just about totally stripped it.
    - Arne
