Results 1 to 8 of 8
Thread: Blaupunkt Radio Question
    Nov 2010
    Fort Worth, TX
    Can anyone help me identify this radio?
    Jim
    Aug 2009
    edmond, OK
    looks like a blaupunkt frankfurt. should have a paper tag on the side with the model number. post a picture of the model number to help identify the year.
    eric
    Quote Originally Posted by 70sporsche View Post
    Can anyone help me identify this radio? Thanks, Jim
    A bit of mixed bag there. The radio looks like a Z-series Frankfurt with the "modern" speaker plug receptacle. Usually found in '69 to '70 cars. The chrome faceplate is an earlier vintage, '65 to '68 or thereabouts. Experts: feel free to disagree.
    I believe it's a 1968/69 serie Z Frankfurt radio with a small chrome faceplate
    Nov 2010
    Fort Worth, TX
    I think it came out of my ‘71E but after 32 years I couldn’t remember!
    Here is the label on the side.
    Jul 2011
    Chicago Area
    Looks like your radio was sent to Robert Bosch Corp. for repair. The original label should be underneath, I agree with enzo it is a Z model 68/69 with the triangle speaker plug and push buttons that are not concave.
    Mike Fitton # 2071
    2018 911S Carrera White
    Nov 2010
    Fort Worth, TX
    Thanks everyone! Is the yellow wire power in? I’d like to test it. And, is it worth anything? Would it be best to reinstall it in my E?
    Yes, the yellow wire is power in. However, do not power up the radio without a speaker plugged into the correct ports. Early Blaupunkts are known to self-destruct if you do that.
    As for putting it into your E, it might fit but the faceplate is incorrect. The proper faceplate has a recessed, frosted-finish center bar. Value? Maybe a few hundred bucks if it works. Less than a hundred if not.
