Thread: windshield washer nozzle
    Jun 2011
    Bellingham, WA
    I bought a new nozzle & I can not squeeze it into the hole
    any tips or tricks to push it in? It is on the passenger side & I can reach it under the cowl
    Aug 2011
    Eugene, OR
    I won't be installing these in my 72T for a couple of weeks, but I remember the same nozzles on the '73 914 I refreshed a couple of years ago were hella tough to pop in place. Interested to hear if anyone has any secrets of tips.
    - Arne
    Oct 2010
    Sweden
    Try to pull it in, it use to be impossible to push them in.
    Light Yellow -74
    @lagteknik
    I use a heat gun to heat and soften the rubber, then I bend the rubber neck back and forth several times to kind of loosen it up, then use a lube of your choice, push nozzle in hole, insert a needle nose pliars from underneath so one jaw goes in the nozzle tube and pull down while pushing down from the top. You will need to pull the rubber almost 45 degrees sideways back and forth while pulling down and pushing down.
    Member Arlo911's Avatar
    Nov 2010
    Ghent, Belgium
    Removing the chrome cover from the nozzle might help. If your car was repainted you might want to check paint thickness around the nozzle holes, if the paint is too thick the nozzle will not fit.
    Early S member #1969
    1987 Porsche Carrera 3.2
    1986 BMW E30 M3
    1971 Porsche 911T
    Jun 2012
    London, Ontario, Canada
    I used Ed's approach, but dropped them in hot soapy water. Same effect. They become malleable and lubricated.
    Ravi
    Early 911S Registry # 2395
