Results 1 to 10 of 16
Thread: Who’s running yellow headlights?
    Mar 2018
    East TN
    Thought it might be cool (re: “different”) to put a set on my car. What should I expect? (I drive this car at night a lot...just sayin’)
    From what I understand, in the u.s., all new cars must be sold with white. Appears legal to change over once bought. (true?)
    Can you see good?
    ‘87 911
    ‘66 304307
    S Registry #3791
    David Cate
    Jul 2008
    South Florida
    Yellow lenses with standard bulbs will be 20-30% less bright than white... contrast will be greater, but illumination will feel inadequate. You'll need 100w bulbs to make up the difference.
    I ran yellow Marchal Amplilux on my 356 but switched to standard (clear) Euro lenses with 55/65w yellow bulbs. Much improved but still not as bright as most would want.
    See John Audette's LED options if you want different and usable (read: greatly improved) lighting. Currently have LEDs on our '68 Targa and they are fantastic.
    http://www.audettecollection.com/
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Good advice. Run with it.
    Early S Registry #235
    rgruppe #111
    Mar 2018
    East TN
    Quote Originally Posted by Bullethead View Post
    Thank you for addressing my question. Good info. Thanks
    ‘87 911
    ‘66 304307
    S Registry #3791
    David Cate
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    Running these on our soon to be finished ‘69E Targa in Golden Green
    Can’t get the full frontal to load right
    Reg#2218
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Nice color. I just sent your sideways picture to my photos & rotated and reposted it here. cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    As the lumen output for the yellow biodes is not the best, i decided to get one of John‘s LED sets, which I can „hot swap“ if in need for extended night drives. I equipped the lights with the connectors, so it is an easy 5min swap..
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Senior Member acoupe's Avatar
    Jun 2014
    Lincoln,NE
    yellow headlites
    on my 66 912 & 58 356A
    Jul 2008
    South Florida
    Before:
    Name:  356 Notch 2.jpg
    After:
    Russ
    ESR # 1537
    '70 914/6 GT
    Jul 2003
    Jacksonville Beach
    Lights
    Ran them on my T.
    Definitely decreased illumination and makes everything you look at appear in a different hue.
    I was always paranoid that I would get pulled over . Sort of like the feeling when your window tint might be too dark.
    1962 356 S Cab gone
    1967 911S Coupe
    2008 RS60 Boxster gone
    1973.5 911T targa soft window Gone
    Runge 008 Gone
    2002 996 TT x-50 Gone
    2016 Boxster GTS pts gulf orange
    1969 912 SWT pts green
    Can I be FRANK with you ?
    Live everyday like it's your last .
    Eventually you'll be right.
