Thread: taillight housing cover gasket?
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    is there a gasket for the taillight housing cover? I took off (what looked like) some "home-made goo/kit seal", but can't seem to find the proper "as-it-was" gasket (if there was/is any)... thnx for infos! Tom
    911S 1973
    Early 911S Registry #176
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    No gasket. Originally they used a non Harding putty sometimes called dumb dumb. The ribeon putty used between front fenders and body appears similar. Your autobody supply house probably can help. Do not use caulk. Rob
    Aug 2011
    Eugene, OR
    Later cars (and later replacement light housings) did have gaskets, though. My left light was replaced many years ago after an accident, and I noted that it did use a gasket that was glued to the housing. The right side still had the putty, although it was pretty dry and crumbling after decades of the car sitting in the desert.
    You can also find an appropriate non-hardening putty at RV supply houses here in the US.
    - Arne
    Jan 2003
    The Netherlands
    Ok. Now I recognize what I threw away.. ;-)
    I might also have neoprene strips I could use.
    thanks!
    911S 1973
