Thread: Attempting headliner install. '68 non sunroof. How important are the headliner clips?
    Feb 2004
    Texas Gulf Coast
    Like the subject says, I'm getting started on a headliner install or attempting to start anyway...
    I looked at PET and it says that 12 headliner clips should be used. When taking my old headliner off I found a total of zero of these. Are they necessary for some reason or will good 3m adhesive do the trick alone?
    Thanks in advance!
    -Jay
    Seabrook, TX
    '68 911T project -The Rat
    '74 911 3.0 EFI Twin Plug toy
    '80 Weissach 3.2 S.S. Grocery Getter
    '70 914/6 GT vintage race car
    Jul 2006
    Corvallis, OR
    Adhesive alone will be good. Never had a problem not using them.
    72S, 72T now ST
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i only install those just because PET says so...
    Aug 2017
    el sobrante ca.
    you can buy some small clamps at harbor freight... I have salvaged the factory clamps and used them as well. but several clamps and 3m glue will do the job. a little use of a hair dryer (don't get it to hot and st
    retch out the material) or even lightly use a steamer. it can be done without heat at all ,,,, but a little can be useful...
