Thread: 1971 pedal assembly to 1965?
    Dec 2009
    Copenhagen, Denmark
    Hi all, I hear from Jim B. that a 1971 pedal assembly will work in a 1965 911 but require some simple mods. Can anyone detail what those mods would be? Thanks!
    James Hurst #1638
    R Gruppe #514
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    if i remember correctly the lever for the gas cable needs some mods(shifted to the left) otherwise it will touch the center tunnel and gets stuck.
    brake light switch bracket(65 does not have this) is different but you can leave as is since it does not effect the function
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    http://www.early911sregistry.org/for...ight=Pedal+box
    Here is a good source for pedal box information & service
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Senior Member Gytis Kupinas's Avatar
    Jul 2008
    West Orange, NJ
    Not sure of compatibility but if you are interested i have 1966/68 pedals set.
    Earlier one is in need of restoration.
    Later one is done and ready to be used.
    Will go on proper forum soon enough.
    For information reason here are the pics.
    Gytis
    1967 911 matching numbers car ( sold )
    1968 911T/R #0805 (SONDERWUNCH AUSSERH DER M.LISTE NR184****) SOLD
    1969 911E MFI matching ALL numbers SOLD
    1981 911 Target 4K ( SHIFT trip-Nürburgring-SPA and SOLD )
    1986 930 "Carnivore" ( "while I'm there" mode )
    Aug 2009
    SF Bay Area
    Quote Originally Posted by zenithblue71T View Post
    Swap the master cylinder actuating rods and remove the brake light switch from the 71 assy.. EASYpeasy.
    Jim
