Thread: Need help identifying struts
    I have acquired a set of struts that I intent on installing on my 1971 911t which has the “S” calipers. The struts I want to install are marked “Koni 911 341041 10 and Koni 911 341042” I have the correct ball joints and lock pins but need to purchase strut inserts.
    Can any tell me what yr/model these struts are from and what inserts I need.
    DanName:  4FD44AC7-2046-4307-ABF5-B6A003CFD796.jpeg
    Oct 2008
    Burford, ON, Canada
    Dan, those appear to have a 1975 date code, so a later version. What struts are currently on the 71? S calipers usually require Koni or Bilstein struts unless you have Hydropneumatic struts..
    Check with Jason at Paragon Products for the inserts
    Thanks, It now has one Hydropneumatic and one Borg? Both have the 3 1/2” caliper bolt spacing. I’ve sent the part # to pelican and asked what inserts they take but haven’t heard back yet. I’ll ck with Paragon also.
    Dan
    Oct 2008
    Burford, ON, Canada
    Beware the Borg, you will be assimilated. However I think you mean Boge.
