Thread: Part# for door glass frame screws
    Hello,
    Do you know the part # of the 2 screws located on top of 'pillar' of the door glass frame of a '70 911 T by any chance?
    Can't find it on the PET Katalog nor on any of the usual suppliers websites.
    Appreciate your help,
    Thanks.
    Olivier
    Name:  Early 911 Registry pic.jpg
    Jul 2006
    Corvallis, OR
    I could never find the part numbers for those. The door latch screws I believe are very close to the same. I found them and specialty hardware store. They weren't quite as large as the originals but very close.
    72S, 72T now ST
    May 2014
    South East USA
    I measured the head on my latch screw #28 and these on the aluminum frame in the photo. and they were the same, and they look the same.
    but the thread length is half that of the latches...the latches are about 10mm and the top top screw is less than 5mm.
    i you bought #28, you would have to make them shorter.
    Thanks both for your inputs on this!
