Results 1 to 7 of 7
Thread: Question on 901 (dog-leg) transmission
    Is it normal that once every 6 or 7 times I put in 1st fear on a freshly restored 901 5-speed transmission, it will resist a bit? Going into second and getting things to rotate at the same speed will take the resistance away and make it easier to go in 1st.
    I heard from some folks that “It is the nature of the 901 transmission”, but I’ve always driven a ‘69 with the 4-speed, so I wouldn’t know... appreciate any thoughts.
    1969 911T #3495
    Member #2793
    Do you know if the rebuild included a new 1st / reverse slider and synchro?
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Nov 2003
    Santa Monica CA
    fresh built 901/911 trans can block trying to go into 1st. after my rebuild, my builder said it will take about 1000 shifts before it shifts easy
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    I am in the "it is the nature of the 901" camp.
    Even well worn, rebuilt 1st is sometimes like that. I think it is Normal with the 901.
    Tucson AZ.
    Aug 2012
    France
    Have driven Fresh rebuild 901 and a 20 years rebuilt, same :
    “It is the nature of the 901 transmission” and its "charm"
    If it does not "grind", then it is ok I would say.
    O-G 26 - Early911S 2407
    Thanks all. It is completely rebuilt, doesn’t grind and its a lot of fun to drive with!
    1969 911T #3495
    Member #2793
    Aug 2010
    Colorado
    With my 1000 mile 901 I lightly blip the throttle to maybe 1500 rpm's to get a little rotation and it slips in to first with very little pressure.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
