Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Bilstein Jack Disassembly?
    May 2006
    CT
    I would like to disassemble my Bilstein jack for cleaning and restoration. From my reading on this, I assumed I could remove the top snap ring from the tube and simply jack the lifting components off the top. Apparently it is not that simple. I was able to jack the components to about 1 inch from the top but no further. Can anyone describe how to remove and reinstall the components after cleaning and painting/plating?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Let us all know when you'Ve been down that road, I will have to disasseble mine too but for a different reason: I'll replace the tube to make mine longer so I can jack the car higher.
    Quote Originally Posted by tom1394racing View Post
    Tom, they should normally lift off the top, but the parts might be rusted, damaged or distorted.
    That's a Volkswagen jack, by the way.
    Jon B.
    Vista, CA
    May 2011
    Chelsea, Québec
    Mine came apart very easily - I've pictures on another computer which I can share later...
    Member #1616
    Aug 2009
    SF Bay Area
    Just remove the spring clip at the top and "jack" it up till it pops off. Very simple.
    Jim
    PS: Looks like a proper 70/71/72 jack to me.
    OK, I didn't think so, but I'll defer to Jim's knowledge on that... :-)
    Jon B.
    Vista, CA
    Jim, did the 70-72 Porsche jacks have VW logos on them?
    Jon B.
    Vista, CA
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
    Yes...........................
    May 2006
    CT
    Jim
    That's what I thought but it does not seem to want to jack all the way up. It stops jacking about an inch from the top. I'll try some rust dissolver and lube to see if I can get it jacked up.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Aug 2009
    SF Bay Area
    Just a bit of steel wool will do it.
