Results 1 to 10 of 13
Thread: FS: Porsche 15x8 & 9 BBS Mahle Wheels - Rare setup
    Senior Member greggearhead's Avatar
    Colorado Springs, CO
    Really rare to have 15x9 BBS Mahle, most are 15x7 & 8. I've had many sets of those, these are the first 9s I've seen. They also have a *slightly* different offset than 15x9 Fuchs. Fuchs are 3mm, these are -2.1, about 5mm difference.
    Good condition, no curbage, does have some mild crazing under the clear coat on the machined lips. OG finish - still has the gold in the reliefs in the lips.
    5x130 Bolt Pattern
    15x8 ET 10.6mm
    15x9 ET -2.1mm
    $1800
    Oct 2018
    Orange County, California
    I believe these are the older (1st gen) version. The stampings are on the lip as opposed to the centers. Curious to know the year (stamped in center)
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
    Thank you. I should have posted it.
    They are all date stamped 11 of 77
    Oct 2018
    Yes, 77/78 is very early for these wheels and I have never seen 9”s. The version (2nd gen) with the markings in the center seem to date from early to mid-80’s.
    Best of luck.
    Quote Originally Posted by greggearhead View Post
    Still available
    Still available
    Still available
    Still available.
    Make offer
