Hi John. Regarding the H1 bulb set, is that per light? So we would need two sets, correct? Thanks.
Scott H.
1969 Coupe LtWt
1973.5 911T
”Lighting Resources for Hardcore Air-Cooled Porsche Enthusiasts”
Thanks John. To further clarify, the H1 takes two bulbs, so I need to order two sets? Is the set; one for the high beam and one for the low beam?
Scott H.
1969 Coupe LtWt
1973.5 911T
Yes, each set contains two bulbs so you need to order two sets for your pair of headlights. With the old technology most of us used two different bulbs: a 55w for the low beam and a 100w for the high beam. And of course the 100w required a relay kit. With the new 90% plus technology we just go ahead and use the same bulb for both beams. And no relay kit required.
JohnA
Thanks John, order placed...
Russ
ESR # 1537
'62 356S Notchback Hotrod
'67 S Das Geburtstagsgeschenk
'68 T Targa Sportomatic
'68 L SW Targa Sportomatic
'70 914/6 GT
Rich Spritz
1959 BMC Huffaker Mk1 Formula Junior racecar
1967 Porsche 911 racecar
1969 Porsche 911T
1970 Winkelmann WDF2 Formula Ford racecar
1973 Merlyn Mk24 Formula Ford racecar
2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
2014 Porsche 991 TurboS cab
2019 Cayman GTS (wife's)
Thanks everyone! The AC Store is hopping today.
JohnA
Ordered a set - in case I ever get to drive my car again.
Ravi
Early 911S Registry # 2395
