Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Question Solex cams
  1. #11
    I have a pair of cams with part numbers that indicate center-lube, but there are no oil (holes) gallies. On the end is stamped Norris 312SRA. Can anyone shed some light on this. Thanks!
    John Schiavone
    Connecticut
  2. #12
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by John912 View Post
    Is it possible a camshaft shop welded some metal over the lobes then ground them down to a desired contour? That would seal the holes in the backs of the lobes if they weren't re-drilled.
    How deep does the central oil gallery go?
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  3. #13
    My guess is that they were just later non centerlube cams. The casting would be the same, just not drilled for the central oiling. Norris was a cam grinder back in the seventies, his cams were popular with the 356 E/Prod. racers.
  4. #14
    Yes I have the same Cams that I replaced in my 68L with S cams , same number but No# but no holes not too sure what to do with them , stored in the garage
Size:  120.5 KBName:  IMG_0692.jpg
  5. #15
    That makes two of us!
    Thanks for info Ed, looks like Norris is out of business and the only charts I could find are for VW and 356
    John Schiavone
    Connecticut
  6. #16
    What is the advantage of centerlube cams and can they only be used with the centerlube engines? Is the lift and profile an advantage to early 2.0 engines. Or can they be retro-fitted to spraybar engines...if of course drilled.
    registry# 1283
  7. #17
    Quote Originally Posted by speedo View Post
    Center lube cams can be used in spray bar towers (housings),it’s just that the holes are not used.
    The holes are there to lube the “bearings”. Apparently (Porsche got away from that after 903070) was it not needed.
    Richard
  8. #18
    Nov 2002
    San Dimas, CA
    Center-lubricated cams are supposed to give better lubrication at high engine speeds while the spray bar is better at low (street) engine speeds. People building race engines love them.
    You need cam chain hosing covers which have the correct oil lines. You also need the "axla" seal to contact the inlet end of the camshaft. I didn't look up "axla" so that may be the wrong spelling.
    Jim Alton
    Torrance, CA
  9. #19
    center-lube vs spray bar
    What are the correct part numbers for the center lube and spray bar towers and covers?
    registry# 1283
  10. #20
    Nov 2002
    San Dimas, CA
    If you're embarking on a major engine building project you should invest in the free parts catalogs (you can just google "Porsche Classic parts catalog").
    It looks like:
    • Left: 901 105 063 01 Lid Chain case Complete with - SOLEX - Carburettor M >> 090 3069
    • Right: 901 105 064 01 Lid Chain case M >> 090 3069
    It's a bit troubling that this mentions Solex carburetors but doesn't mention center-lubricated cams and I'm not sure the changeover was at the same engine. But, the illustrations in the hardcopy parts catalog show the center-lubricated fittings in these covers.
    Jim Alton
    Torrance, CA
