Thread: 215/60/15 on 7" in front?
    Oct 2004
    SW Suburbs of Chicago
    Will 215/60/15s on a 7" wheel fit without issue on the front of a stock, non-flared 72-73 911? I'm currently running 205/50/15 on 7" in front and 225/50/15s on 8" in back. Intending to do a lot of long-distance driving, I'm looking for longer legs. 215/60/15 in back will work, but I am thinking of going with these (below) in 225/60/15 and if they'll fit, 215/60/15 in front. That would mean diameters of 25.6" in back and 25.2" in front, versus 23.9" on the 225/50/15s and versus 25.4" on stock 185/70/15. Anyone run 215s in front without issues? Thanks.
    https://www.tirerack.com/tires/tires...5TPT&tab=Specs
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    I've seen 215/60 on 15x7 at the front of a narrow-body 914, which has what seems like a more restrictive fender opening, and would be curious to hear if anyone is running them on the front of a narrow-body 911.
    While 215/60 front with 215x65 or 225/60 rear might get you the longest legs (if they fit), 195/65 & 215/60 would be a known qty that gains ~2 inches in overall diameter on the driven wheels (vs only another 0.6 inch with possible fitment issues). If you didn't reset your speedometer for the 205/50s, the 215/60 would also get you close to "stock" accuracy, as well. I used to run 205/55s, and moving to 185/70s noticeably improved my car's freeway legs. Tires are funny when it comes to dynamic interference clearance, as the 205/55s never touched any bodywork but the 185/70s can occasionally lightly catch an edge of my front spoiler when coming out of a driveway just so. I'd be wary of staying with 225s in the rear while increasing overall tire diameter—a 225 rear that doesn't burn the paint on your rear fenders as a 50-series tire just might as a 60-series tire depending on your ride height, fenders, etc. Of course, tire sizes vary across manufacturers—so a 225/60 might be bigger or smaller than a 215.
    Looks like those Uniroyals can be had in a ton of sizes close to what you're looking for...which is more than can be said for so many tires these days. Al of the 60- and 65-series mentioned in your post and above look to be available...that's already a win.
    Oct 2004
    I should have mentioned I have RS flares on the rear, and the speedo has not been recalibrated. 215/60/15s on the rear and 195/65/15 in front are option A. I just like the look of fatter rubber, and saw the Uniroyal are available in 225/60 and 215/60, so they are option B, as long as the 215/60 will fit, or, 195/65 in front, option C. Thanks for the thoughts.
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    Quote Originally Posted by EsGeht View Post
    I think you will have some issues with the 215/60/15s on the front. 205/60/15s should not be a problem. I'm not a fan of 7s on the front of a 911 without flares, though. Porsche runs 16 X 6 wheels on the front of 964s with 16 X 8 on the back. I have run 15 X 6 with 205/60/15 on the front of my RS flared (rear only) 911T and 15 X 8 wheels on the back with 215/60/15s with no problems. I'm currently running 50 series tires on both ends cause the car is more track focused at the moment. Same wheel combo, though.
    Reegards
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    I certainly don’t want to hijack your thread, but I actually just bought some of the Uniroyals from Tire Rack as well but got 185/65/15, as I was looking for an inexpensive option that I can throw on an extra set of 5.5” Fuchs. I will let you know how they work out, as they are definitely “outliers” in the tire community. At $59 each and an H rating, it was hard to not give them a shot!
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    Oct 2004
    Yes, thanks, Scott!
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
