Results 1 to 9 of 9
Thread: Clam shell removal
    Clam shell removal
    Guys I need a little help on how to remove the clam shell on my 69. I have removed the two tiny screws on the sides, does it now just snap together or is there something else? I don’t want to try prying it apart unless I’m certain that’s how it comes apart. TIA, Mike M
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Aug 2009
    SF Bay Area
    You need to remove your steering wheel and find the 4 screws that attach the clam shell to the column.
    Aug 2011
    Eugene, OR
    If it's the same as my early '72, there are 4 screws under the steering wheel as well.
    - Arne
    Thank you both. Not that pulling a wheel is a big thing, just seems more complicated than need be
    1969 911S
    Aug 2009
    SF Bay Area
    Your steering wheel will come off in 30 seconds with the proper tools.
    Using a hammer and a chisel will take a minute or 2 longer.
    Jim, I meant the clamshell removal not the steering wheel I have a steering wheel puller, provided it’s similar to most.
    1969 911S
    Aug 2009
    SF Bay Area
    You don't need a puller.
    You don't need a puller, it pulls right off.
    I like easy!!
    1969 911S
