Thread: fuel pump - help identify (911 - 1969 T - 2liter on webers)
    Junior Member
    Sep 2017
    Athens Greece
    Hi all,
    can you please help me identify the shown fuel pump?
    Is the the right one for this car?
    Any improvement proposals?
    thanks
    Christos
    911 T 1969 coupe LWB, Tangerine 2.0L 4-speed / Greece
    The bracket is correct original, but....no clue as to what pump is in your photo.
    '69 2.0 Weber 911Ts came originally with a Hardi fuel pump.
    I believe they're still available from Pelican...not the best. Mine came with a box of four dead ones from the original owner!
    Name:  '69 in pogress, engine circuit board.jpg
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Looks like a FACET
    Nov 2014
    Port Orange, FL
    Yes -- it IS a Facet (far better than the Hardi) They are available through the Aircraft Spruce catalog.
    Junior Member
    Sep 2017
    Athens Greece
    many thanks for the input, you guys have always been helpful. Only few similar cars in Greece so the know-how and experience is missing. So i guess since engine works fine there is no reason replacing this pump with a better. Also ni CDI is fitted.
    Any other improvements worth considering?
    thanks for the feedback,
    Christos
Tags for this Thread
