Results 1 to 10 of 11
Thread: Sport Seat belt bolt size
    Dec 2013
    Connecticut/Florida
    Need some help...I can't seem to find the correct size bolt for the hole pictured here. The sport seat has a bolt hole on each side. The inside for the receiver works fine with a seat belt bolt that I have. But none of the bolts will take on the outside hole, the one pictured here - and I have the same issue on each seat.......Its possible it has some powder coating in the thread, but before I try that fix, can someone tell he what's the correct bolt size here? Thanks
    1971 911S Coupe - Gemini Blue
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    metric->M12
    lenght: 14mm
    SW19
    Die schönste Rennstrecke der Welt. Nordschleife's Avatar
    Dec 2006
    Just a guess, but if Dirk07’s M12 recommendation doesn’t fit, you might try a bolt 7/16”-20 thread pitch.
    The large US auto market (and Department of Transportation safety regulations) drove auto manufacturers around the world to adopt that bolt size many years ago. It’s a funny thing, where every bolt in a German manufactured car is metric EXCEPT for the seat belt bolts, which are very often 7/16”-20.
    BTW, some of these seat belt bolts for German cars have metric heads (e.g. 17mm) but the threaded portion is still 7/16”-20.
    Early 911S Registry #1246
    1968 Porsche 911 Cotswold Blue/Schwartz #118 35153
    1962 Marcos G.T. 1000 Gullwing historic race car - now sold and racing in FIA events in Sweden
    "Pro Patria Vigilans"
    Aug 2011
    Eugene, OR
    Even more odd, I wonder if 7/16" x 20 was selected because it is virtually interchangeable with M11x1.25. Really. Check the math.
    While M11 isn't common anywhere, having a metric alternative means that automakers in metric parts of the world didn't have to buy/build non-metric tooling.
    - Arne
    Quote Originally Posted by Simonjjb View Post
    It's a DOT 7/16 fine pitch....you'll find that thread size and pitch in the belt anchors even in the tubs from '68 on. DOT mandate as of '68.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Dec 2013
    Connecticut/Florida
    Thanks all !
    Quote Originally Posted by Nordschleife View Post
    Yes. I've been down this road too.
    Early S Registry #235
    rgruppe #111
    May 2011
    Chelsea, Québec
    This is why I love the Registry... where else can I follow stories like this whilst on lockdown nearly at midnight on a Monday?
    Member #1616
    Apr 2016
    Stuttgart, Germany
    Sorry my fault. Too late, kids, Homeoffice,.....
    Forgot to post the complete text.
    7/16" UNF is the standard.
    I have seen some "modified" bases with M12
    All of $4.60 if you need to clean up the threads. Do not use a tap.
    rgruppe #111
