Results 1 to 1 of 1
Thread: Hotrod / Sports Purpose Headlight set - Biode like - Set #3
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    I’ve put together 3 sets of headlights from parts that I had lying around from way back, when I was building the Cibie Biode Replica’s and later on restoring some other headlights that sometimes came with other light parts when I bought someone’s parts stash.
    I was toying with the Idea of building lightweight Biode Type lights, but it was not really a priority, so it had a very long lead time. By now the 7” Biode Replica’s will be well on its way to completion now and hitting the market soon....But.... those will require a SWB Headlight bucket set also. So they will be way over $1000 as a total sets and you will still have to restore the SWB lamp housings and rings.
    I’m offering these as cheap alternative for your hot rod or sports purpose look 911 and I’m selling them for the money I have in them + shipping cost. So basically all the work (around 4 hours+ a set) and some obsolete parts is for free.
    Set #3:
    I’ve altered a Hella Reflector to accommodate a secondary Cibie Biode small reflector.
    All 4 reflektors are professionally restored with Aluminum coating after all the adjustments.
    In the back of the reflector I have put a H4 conversion bulb and new rubber buffers all around.
    (You have Normal beam, High Beam and the secondary H1 on top of that)
    The buckets are Bosch buckets that are fresh zinc coated. Lens is a new Bosch 911 SWB lens.
    Rings are VW rings that have the tab removed and the hole drilled/indented to accept a screw.
    (Of course you can switch out the ring with your original 911 rings and then you will have the Euro 911 SWB headlight look.)
    Coating 4 reflektors 200 euro’s
    Coating 2 Buckets 30 euro’s
    Cost of parts 150 euro’s
    Shipping 45 euro’s
    Total 425 euro’s
    Converted to USD the set is $460 paid as friends with paypal
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
