Results 1 to 1 of 1
Thread: FS: Restored Pedal Set 1969 - 1973
    May 2006
    Riverside CA 92505
    I have this restored pedal set for sale. If you want a period correct pedal set this is it. It is correct only for a 1969-1973 LWB 912 or 911. It can be used for SWB cars using the dual circuit master cylinder.
    These LBW sets had a longerer clutch lever arm which was superceeded by Porsche from the earlier SWB shorerer arm .
    The LWB cars use a shorter brake rod and have the brake light switch on the pedal set housing.
    The pedal set parts have been thoroughly cleaned before zinc plating and powder coating. The only parts not plated are the brake pedal and lower clutch arm.
    Reassembly is with new bronze bushings, rubber stoppers. Stainless steel cotter pins and washers are used to resist rust.
    Price is $300 with a good core. Good means no rust holes through the housing. Some missing or damaged parts are acceptable.
    Price without a core is $450.
    I can ship the pedal set before your core is received. I work this through PayPal by charging the core charge. When the core is returned and inspected the core charge is refunded.
    I build pedal sets for all 911, 912, 914's and have finished parts on hand for quick turn around. I can also restore G50 pedal sets.
