Results 1 to 8 of 8
Thread: Rear centre part: “bolt/nut” or “tapping screw/speed nut”
    I have a fairly detailed and potentially “geek” question.
    I always thought that the tapping screw was used to fix the rear centre part to the bumper corners.
    This conviction was strengthened because of the tapping screw and speed nut I encountered on a model 1967 and a model 1973.
    However, when I look at the PET, there is a bolt in the -68 scheme and a tapping screw in the later 69-.
    What is your experience? Would a bolt and nut be (more) correct for a model 1967?
    For what its worth,,,,I've only ever seen the sheet metal screw into a clip nut.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by TailHappyTorquelessWonder View Post
    i also noticed this recently and was wondering a bit since i`v never seen bolt and nut. sheet metal screw and speed nut is the way to go i`d say.... what i`v seen once on a SWB bumper corner (that looked pretty original to me)was a clip/speed nut with metric thread .years ago i bought +50kg of bolts and screws etc from a german porsche 911(mostly swb) dismantler and found several of those threaded clips.
    Oct 2010
    Southern Ca.
    In real life , (original cars) the bolt head is opposite of the PET , the head faces the license plate panel .
    May 2014
    South East USA
    Photos from an original paint. Low mileage 1971 T.
    And I think there is a white plastic washer, maybe aluminum, between the painted parts. Causing a gap.
    There is certainly the gap.
    And a bonus image, showing the other bolts.
    In the LWB cars, the speed nut and taping screw were used in my experience. 2 per side large OD ALU washers were used to produce the proper gap between license panel and the bumpers in many cases.
    Speed nut/Sheetmetal screw is the only set up that makes sense with the muffler installed...just R&R'd my license panel yesterday and can't imagine trying to assemble a traditional nut/bolt fastener on each end of the panel.
    Thank you all for the input.
