Thread: Sunroof power 1969
    Junior Member alphi's Avatar
    Nov 2017
    France
    Sunroof power 1969
    Hello
    A technical question for my first post!
    On a 911 1969, there are 2 boxes of 8 fuses
    On the wiring diagram, the sunroof (switch and after motor) is powed with fuse N°8 of the 2nd box (see pictures attached)
    But how is this fuse powed, a wire coming from the first fuse box like fuse N ° 6 or a wire coming directly from ignition starter or another ?
Size:  187.9 KBName:  5FEBFB23-FE30-4C67-81A9-C15C77A2FDDC.jpg
Size:  172.4 KBName:  8DB11DA7-8880-4B01-8FD1-16AFE7908E36.jpg
Size:  192.3 KBSee attached diagram for 70-71
    Follow the various wires for #8 sunroof....
    Looks like there is a red wire from the #62 WECO connector up to fuse #6 also note another red from #62 to the 4 post rear fuse panel.
    Hope these help Name:  CC731B73-AA45-43A7-9A19-BF0F079E7CBE.jpg
    More to come
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Nov 2017
    France
    I was thinking of fuse 6 because the power (one of the two red wires) comes from the ignition starter position 1.
    This terminal of fuse 6 supplies power to the fuel pump (blue and yellow), the wevo connector you are talking about 'other red wire), the HKZ, the fuse box in the compartment motor
    I don't see any other fuse for the power for the sunroof or perhaps there is another wire coming from the ignition starter
    I would like to see a photo of a fuse box (without the covers) of a 1969 (with 2 fuses box) with a sunroof
    Nov 2017
    France
    Finally I fed fuse 8 (sunroof) from the rear window heating switch
    It is ultimately the only place I found (?) to power the sunroof from position 1 of the key switch which is the radio position (radio and heating fan and now sunroof !)
