Here we have a mechanical fuel injection set up for a
69-73 911E with 32mm throttle bodies
The stacks/intake tubes are in excellent condition and
has more of the factory original linkage and brackets still attached than
I can find on any other unit no matter what the price.
Both of the throttle bodies are there, but are good as
cores only. The butterflies will not move. The factory original fuel lines are included with this purchase as are
the factory original brackets attached to the lines. 4 of the fuel lines have had their
ends cut off at some point, but are still good to use as a template for
remaking lines that are bent to exact factory specifications.
These parts were found on a shelf covered in dust. We simply wiped them off,
and put them here for sale.
These are sold AS-IS
$1000.00
