Thread: Gasket failure
    Gasket failure
    Anyone have an explanation for this. Gasket between top of stack and air box on 69s. Looks like gasket got soft and then sucked in, however bucket to stack bolts were all tight.
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Those paper gaskets shrink all by themselves. Add some cold start from spray bar and I suspect it would be worse. I would eliminate the spray bar cold start, and use only the injection pump cold start system.
    Aug 2010
    Colorado
    That picture would make a nice poster.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Hey Chris, I’ll sell you the rights to the photo for the price of a new gasket
    gled49, makes sense, perhaps one of the spray spray nozzles is skewed a little towards the edge. I know that a PO had the throttle bodies rebuilt, maybe they replaced the gasket with an inferior product. Then again, one would think that any gasket used around the fuel system would be impervious to gasoline.
    1969 911S
