Thread: 911s camshaft stamping on end of cam
    Apr 2012
    SE PA
    Hello,
    Isn't there a number stamped into the nose of the camshafts on S cams so you know what your dealing with when setting cam timing?
    I am thinking 54 or something?
    It,s a 73S but never thought it came on at 4500 like other S cam cars I had driven.
    Installing the MFI that was on the car from new after getting it redone and I want to make sure about the cams.
    Thx, John.
    Junior Member Pancho RSA's Avatar
    Apr 2020
Size:  94.3 KB This is a Camshaft chart where you can find information about it.
    May 2006
    CT
    I use this camshaft cross reference. The casting number is usually cast into the shaft. For a 69-73 S you'd be looking for the 167 (LHS) or 168 (RHS).
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Apr 2012
    SE PA
    Can I see the numbers with the cams in the engine?
    May 2006
    CT
    The cam tower blocks the line of sight to the stamping on the shaft.
    Tom Butler
    1973 RSR Clone
    1970 911E
